Hi everyone......we are new to the site and hope to be able to gain some new ideas as well as contribute some of our own tips and tricks. We have a 1984 Passport that is in the process of a refit. She's inside of a shelter that we constructed behind my shop here in Vermont.
On the slate is removal of the teak decks and replacement with something else, redo of the plumbing and electrical systems and rigging.
Having ripped out all of the old plumbing (yuck) , we are getting close to wanting to clean the bilges completely so that we can prep for a new coating of paint.
Question for the day ....has anyone had good success with a product and method of cleaning out 24 years worth of 3 prior owners bilge grunge? What type of paint would be good for this job?
Thanks in advance for any help that can be offered.
Ernie
Cleaning the bilge
Cleaning the bilge
Ernie
S/V Iemanja
Vermont
S/V Iemanja
Vermont
Hi Ernie, and Welcome to the Forum!
Ernie wrote:
http://plasticclassicforum.com/viewtopi ... ilge+clean
Here are a couple related to bilge painting:
http://plasticclassicforum.com/viewtopi ... ilge+paint
I'm sure everyone will be very interested to hear more about your boat and your other projects. And your shelter!
Again, welcome.
Ernie wrote:
In addition to any new info that might crop up in this thread, here are links to a couple of prior threads on bilge cleaning that Suntreader started (his bilge was super-oily when he started his project).Question for the day ....has anyone had good success with a product and method of cleaning out 24 years worth of 3 prior owners bilge grunge? What type of paint would be good for this job?
Again, welcome.
Iemanja's ship shed
Rachel.....thanks for the links. It sounds like this is an ongoing problem which is why I thought you all might have some good answers. Here is a link to our ship shed, which I know from reading other posts here, is a very interesting topic.
http://picasaweb.google.com/Iemaventure/TheShipShed
Ernie
S/V Iemanja
Vermont
S/V Iemanja
Vermont
Hi Tim....yes...you are correct in that after the fact we wish that we had left some additional space along the sides. This was a monster to put up and we were pretty tight on beam space in the first place so making it wider also would have meant that we would have wanted to make it taller...As you can see, it was a stretch to get up there as it was.
The teak came up well but our backs did talk to us a bit!
We will be following some of your great tips in filling holes and refairing the deck in the months to come. Your site has certainly been great to look through....its stimulateing lots of questions to come!
Regarding the size of Iemanja....yep.....she is all there. We are hopeing to do some extensive offshore cruising if all the stars line up and we really wanted to have a solid blue water boat that would take good care of us. It was a bit of a stretch $$ wise but being that I am in the marine business ( I own a canvas shop here on Lake Champlain), and Bette and I are able to to many of the projects ourselves, it makes it affordable for us.
Thanks again for the great site and I look forward to lots of info to come.
Ernie
S/V Iemanja
Vermont
S/V Iemanja
Vermont
Consider not painting!
If I'm not mistaken Passports have gelcoated bilges? If so I would NOT recommend painting. Even the best bilge paints will eventually begin to peel, chip and flake off, as NONE of them are impervious to moisture penetration even Bilge Kote, and they will potentially & eventually begin to clog your bilge pumps with paint flakes.
If it's gelcoat it CAN, in most cases, be made to look as good as new!!
Here's a photo of my 30 year old factory gelcoat bilge! It took me about 8 hours of hands and knees cleaning with On/Off (acid based cleaner to remove rust stains), Acetone, MEK, 3M Sharps Shooter industrial floor cleaner and Mr. Clean Magic Erasers but it literally looks better than new..
I have painted bilges in the past and will NEVER do it again. If I needed to protect a bilge I think I'd use Interprotect 2000E (once the substrate was totally dry) or gelcoat..
You realize of course that a little indentation in the floor under the floorboards bears little resemblence to the bilge on a full keel boat. Our bilge is approximately three feet deep and five feet long. Cleaning the bilge requires long handled mops and lots of elbow grease! I only wish our bilge was only a couple inches deep!!!
The wind protects and prevails...
No you don't. No, really, you don't.Liberty28 wrote:I only wish our bilge was only a couple inches deep!!!
While it might look pretty, if you have the most minor of leaks, your bilge will be full. Water has no where to go but out of the bilge.
Bilge pumps are a pain because a pump of the proper capacity for the boat doesn't always fit in such a shallow area-- you need to use a remote pump.
I miss my big, deep bilge!
