I'm not even sure that "sleeker" is a word, but once I got beyond that, the 1"/10' rule stuck in my craw a bit. I read on.A proper (painted) waterline should be raised (above the actual waterline) 1" for every 10' of the boat's length... this makes the topsides look narrower, which makes the boat appear sleeker.
I'd never seen these principles applied to actual mathematical ratios before. Interesting. In application, a Triton's painted waterline should be 2.8 inches above the actual waterline, the upward swoop at the ends should add about an inch and a half to that height, and the boot top should swoop about an inch....the line should curve upward. This compensates for the waterline receding inward toward the stem... To find the waterline's high point at the stem, divide the waterline length in inches by 160..... In addition a proper waterline is always crowned with a boot topping.... As with the waterline, the boot topping should curve upward. To find the boot topping's high point on the stem, divide the waterline length in inches by 220...
Anyone ever seen or used such ratios before?
Tim, doesn't it make you feel silly for all of that taping and squinting you recently endured on the Daysailor?? You could've just ticked-off a few measurements and been done!!! (joking. easy, killer)
