i am trying to square up some outside corners. Can i use packing tape as a mold release on either side? I have a flat board wrapped with tape to form one side as a mold. i plan to work the epoxy up to the mold with a spreader.
Chris,
depends on how smooth the wrap is. The smoother the wrap, the less sanding you have to do. A good waxing would do as well or better, or even hairspray, or Pam cooking spray. Just make sure your board is as smooth as you can get it.
Larry Wilson
While I haven't used packing tape, I have used Scotch tape. It is usually made of some type of non-reactive plastic (PolyEthylene or something). The Scotch tape works great. Problem with Scotch tape is it only comes in small widths.
I would suspect packing tape would work as well, however, I would test first on a test piece of tape.
"Scotch" brand (3M) also makes a packing tape. I don't see why it wouldn't work; epoxy is not particularly reactive with most materials, and is actually fairly inert when mixed.
