Interdeck: Re-tape betweet coats?
Can anyone with Interdeck experience suggest if it's better to pull the tape between coats and re-tape, or if it'll pull clean after the second coat goes on.
I'm using fine-line tape for the edges and blue tape over it to widen the masked area.
Thanks!
Thanks!
Greg
Truelove - WC Triton #105
Well, I haven't used Interdeck with Fine Line tape, but I've had no problem pulling up both #225 silver tape and #233 green tape after two coats.
Just don't leave the tape on any longer than you have to, assuming you're outdoors. Do 2 coats in 2 days, and try and pull the tape off the second day.
Good luck!
Good luck!
- Peter
- Boat Name: Pagan
- Boat Type: Albin Ballad 30
I didn't use Interdeck, but when I did my non-skid (two coats) I simply double-masked it. After applying the first coat I stripped off the top layer of tape, then took the second layer off after the second coat.
It's a bit of extra work, but I used a Duradeck-type coating, and if you let it dry at all it tears unevenly on the tape line. I ended up with a very smooth edge.
Hey Peter - the double masking tape is a great idea, I'll have to remember that one.
Here's a before and, not "after" since she's a ways from being done, a "current" photo of the boat.
Standard West Coast Triton. The original gelcoat was red but in poor condition. Now she's back to her original color with her new paint job.
Greg
Ancient Race
