Triton 106 is a west coast boat and it has an out turned flange for hull deck joint (see drawing below - apologies for the rough drawing, but I don't know how to use a CAD software). I haulled my boat out in a local boat yard (Svendsens) yesterday and could not wait to tear off the old rubbing strake this morning. It only took a few minutes to tear it off but cleaning up the mess under it took me couple hours with a grinder.
To my surprise the joint condition is not bad. There is only one section (about 10 inches long) with loose resins (I assume that is what Aero Marine used as the joint compound). My questions are two fold:
1) Is the joint strong enough with only internal fiberglass tabbing to hold it together? I don't know how many layers of glass Aero Marine used but would guess two or three layers but they appear to be in good condition.
2) Would you replace the old rubbing strake with the same rubber one (it is still available at a local manufacturer in California - see NTA website) or would you replace it with one milled from teak?
My own instinct that the joint is not strong enough for my intended offshore ventures (yeah, sure :-) - but one has to have dreams) and some kind of mechnical (machine screw and nut) or chemical (external fiberglass tabbing) bonding externally will be needed to strengthen it. Since the joint is externally flanged mechnical means will be easier, especially in the midsection since the bottom flange has enough space to accommodate nuts. However, the screw heads (if pan head screws are used) and nuts will certained interfere with my idea of a teak rubbing strake.
I read Hal Roth extensively modified Whisper's hull to deck joint. My understanding of his writing (it's hard to tell since he did not provide any pictures or drawings) is that he completely ground off the flange and laid 4 layers of glass tapes (1", 2", 4", and 6"). That's a little more than what I have time for.
Your thoughts and experiences will be much appreciated, but I need them soon as I plan to finish the bottom job and fix the joint within this week (I know it will never happen but I like to set ambious - unrealistic - goals).
Thanks and best regards,
