Backing Plates
I'm not sure if these qualify as "iffy," but I see a few things I would have done differently:
1) It doesn't look as though the core around the chain hole is reefed out and backfilled, or otherwise sealed off.
2) Why so many little individual backing plates? I think I would have gone for fewer but larger. What's up top? I assume there could be cleats or other high-load items.
3) Unsealed (?) plywood (although it does look like decent plywood). I'd probably use some type of FRP board (such as the red or green from McMaster-Carr).
4) I see rust around/between the threads and nuts on the center item. To me that means that water might have been leaking here, and given that you didn't do the job yourself, who knows what kind of attention was paid to the core in those areas?
5) Now I'm really nitpicking, but it looks like there may be (white) sealant between the backing blocks and the underside of the deck. This may be just my preference, but I like to put sealant between the deck hardware and the deck, but not between the backing block and the underside of the deck. If it's leaking it's time to re-bed, and I'd rather know that than have water lurking betwixt and between.
6) All that said, nothing looks like it's moments from failing, so depending on what else is on your list, it may not need to be first priority.
I presume that's an uncored deck, or a very thin core, judging by the section revealed at hawse hole (right term?). What are the bolts for, winch and/or cleats? What's that lonely little pan head screw?
Looks like body washers, rather than the size usual for the bolt dia. (Body washers are thinner and larger.) I think I see that at least one is dished in by crushing the wood block. Two blocks are/were wet. Bedding goop shows on only one of the 7 bolts.
On one hand, you haven't told us that things are falling off. On the other hand, if you are looking for a project, I think all those blocks are way too small, and the half on one is not very functional. I'd prefer that the groups of three bolts share a nice large aluminum, stainless or fiberglass backup plate. I'd have eased corners, too, because I hate to bleed all over while assembling things. I'd have made a mess with bedding goo; maybe your PO was neat and there really is enough goo.
- Boat Name: Andiamo
- Boat Type: Alberg 35
Simpson Lawrence HiSpeed....I love mine.
I should have taken some pictures of my mounting last weekend. Looked like yours, but no ply, just washers!
I am building 1/4 al plates for it this week and mounting tomorrow.
I'll take pics then.
