I am looking for pictures of the compression post step that is in the keel. I have heard that it is one block of wood in there, but others have noted several pieces of plywood in there. I want to cut into the fiberglass to inspect but I would like some pictures before I do.
I do plan on Sailing my boat while I own it. :wink: so I don't want this to be a summer long project.
Any help would be great.
Catalina 27 mast step question
Clint
"BRIER PATCH"
1976 Catalina 27
"BRIER PATCH"
1976 Catalina 27
Catalina (along with several other manufactures) is infamous for things like this being differant from hull to hull. A hardwood block was called for, but it may be as simple as the factory was out of that particular piece that day, and used ply scraps. My 27 had the hardwood block, but the position of the block and the condition of most of these block that I have seen prevent pictures from being much help. They end up just looking like a photo of a black hole!
In my opinion, the most succesful repairs of this block where done with pieces of prefab fiberglass and epoxy. That being said, there is nothing wrond with epoxy saturated wood, and done with care, even the wood will likey last the life of the boat.
I know at least one member of the Catalina 27 trailer sailor board has done this repair in the last year or so and may have the pictures you would like to see.
Good luck!
Good luck!
Clint
Ironically enough, the job is easier if the block is rotten! I cut the glass and dug the block out with a chisel, a dremel and myriad other pointy and sharp instruments. The replacement was a block made up of several pieces of 1/4" (it is what I have a lot of) prefab fiberglass and set is a bed of thickened epoxy.
It is not a hard job, just a bit cramped. I recommend a pair of work gloves, as the close confines will tend to leave you with scarred knuckles in a hurry.
Ryan
Ryan
Oscar
- Boat Name: Lady Kay IV
And from year to year. I have heard of people dong the job and replacing the block with IPE......Catalina (along with several other manufactures) is infamous for things like this being differant from hull to hull.
Shouldn't take too long. I did the engine bed on an old Catalina 30 and a few days was all it took, including the trip to the barber to get a crew cut and lose the pancake of epoxy I put in my hair while hanging in there upside down...... 8-)
