I'm replacing the traveler on Luna as part of my restoration - the old one wasn't working very well and I had to remove the 'glassed-in towers as part of my deck recore anyway - so I've got a blank slate to start with.
Background: the stock traveler on the Yankee 30 is on the cabin top, it runs across the aft end of the sea hood, and is a straight piece of track.
For replacement, I see two options:
1. Get a straight track traveler from Garhauer (could be elsewhere, but I like their stuff and their prices) with a pair of risers to lift it above the companionway (1 pair UR-1, 1 MT-UB1). This would be essentially the same thing that I removed, although the risers would be metal instead of 'glassed-in blocks of wood, so they'd be less visually obstructive.
2. Get a piece of aluminum bent to match the curve of the cabin top and have a piece of track bent to the same shape to bolt to it - thus giving me a curved traveler which wouldn't stand so high off the deck at the ends. This would be more of a custom solution, but might look better - and probably would cost about the same since the track wouldn't need to be as strong, since it would be supported all the way along.
The advantage to #1 is that it's an off-the-shelf solution, I just bolt it in place and go. The advantage to #2 is that it might look a little better, and be easier to see over when seated on the cockpit seats (which is where I'll be, with tiller steering). I have seen boats equipped both ways, and can't think of any functional reason to prefer one over the other - so it's really just aesthetics.
Here's a picture of another boat with method #1 in place:
And another with #2:
Any thoughts?
Chris
