Her decks were recored with divinycell, professionally by a yard somewhere in Maine - presumably near her previous home in Addison. I've got pictures of the job on my site - they look good:
I think they used polyester resin, and doubt they used biax, but otherwise it looks like a good job.
Here's the thing, though - the decks move underfoot! As I walk around the decks - these freshly, professionally recored decks, they squish a bit with each step. I don't know, but I assume that this is a result of the foam compressing - but it feels funny, especially for a boat with freshly cored decks.
Does anyone have any suggestions as to: a) why this is happening, and b) what I might do about it?
I've been pondering sanding off the paint they put over the decks and putting an extra layer of 'glass. I've also considered adding thickness to the decks from underneath, since I know the bottom skin is skinny on this boat. But I don't really have any idea what is going to bring me satisfaction, and would rather avoid trying things at random until I hit it.
As always, any and all suggestions greatly appreciated!
Chris
A note on Yankee 30 soft decks: Turns out that while the Yankee Yachts company had some great ideas about how to build boats and do it well, they did miss the boat (so to speak) on a number of issues. First and foremost of these is how to build a cored deck. They correctly sandwiched balsa between sheets of fiberglass. They correctly layed it up with good resin in controlled conditions with expert workers. They then left the edges of the balsa core exposed, covered only by a teak toe rail, with bedding compound between the toe rail and the balsa core. Sigh. Of course I write this with the usual 20/20 hindsight, but even so - I've never seen this anywhere else - all that has to happen is the bedding fails, and there you are with your decks rotting out from under you!
