Rudder stock tube question
gbraun
- Boat Name: Varekai
- Boat Type: Islander 32 Mk II
Can anyone tell me what the fitting is? This is a picture of the rudder stock housing, I'm getting ready to cut it open to install a quadrant.
Re: Rudder stock tube question
Looks like it might be a grease zerk. You pop on a grease gun on this zerk and shoot grease into the rudder tube.
Just a guess.
- Case
Just a guess.
- Case
- Chris Campbell
- Boat Name: Luna
- Boat Type: Yankee 30
I'm sure you've thought of this - but you are aware that once you've cut that tube you'll need to keep water out of the boat through another means, right? Currently the tube is long enough that the top of it is above the waterline (like your cockpit floor) - once you cut it you'll need to install a packing gland to seal things up again.
Sorry to state the obvious - just making sure that it was indeed obvious!
gbraun
Chris - Yeah - I thought of that! didn't originally, but Edson website on tiller to wheel conversion had it noted.
