Hi. I have the metal board out of my 19' Oday Mariner. It has been sandblasted. I am looking for advice on the painting process.
The boat will be moored in salt water.
I was going to seal with epoxy, epoxy fair and then put on 4 coats of bottom paint. Is this the correct procedure.
Thanks for your thoughts.
Painting iron centre board
Triton 185
Yvon Chouinard
Yvon Chouinard
Re: Painting iron centre board
If it were me, I would go with 2 or 3 coats of bottom pint over 4 good coats of epoxy The epoxy will act as a barrier coat.
- Wood Whisperer
Research Coal Tar epoxy. It's what is used on offshore structures, and will hold up a LONG time. I've used it under the bottom paint on both of my cast iron keels, with excellent results.
One warning- the stuff really stinks while curing
Popeye1865
Devoe, Bar rust 235
another industrial epoxy coating specifically designed for steal surfaces designed to be submerged
