HVLP equipment
Jfwtc
HVLP equipment
Looking for suggestions for the best HVLP spray equipment for applying Awlgrip without breaking the bank! JFWTC
Wayne
I'm using this turbine system from TP Tools:
Showtime 90 HVLP Turbine
They regularly sell "slightly damaged" units on Ebay, which is how I bought mine. There was no sign of damage on my brand-new unit.
Buy the gravity-feed gun, whichever gun you choose. It's much easier to use than the other type.
I found with Awlgrip that it was best to use the slowest reducer (hot weather reducer) with this turbine gun because the turbine slightly warms the air; this was causing the regular reducer to flash too quickly, creating orange peel in the surface since the paint couldn't self-level fast enough. The slower reducer greatly helped in orange peel reduction.
If you have a compressor, you can just use an HVLP conversion gun with your compressed air. I don't have a compressor at this point, so I stuck with the turbine for the moment.
I think it depends on what you have in your shop, and what you intend to do. If you don't have a compressor and don't intend to get one, the turbine is a good option. I think compressed air probably works the best for spraying in the end, but I've been happy with the turbine.
Rogue Sailor
I have a FUJI HVLP system which I used to paint Interthane Plus two part epoxy paint on my Tanzer 26 hull. Its a great machine. I've used the optional top feed gun for touch up work and for applying spar varnish.
http://www.FUJISPRAY.COM
