Dimensions (approx)
LOA: 20'-7"
Beam: 6'
Draft: 3'-6"
Construction:
Solid fiberglass. Keel reported to be integrally molded. Unbalanced spade rudder (not installed, but present on the cradle). Hull reportedly shows signs of a previously-installed full skeg forward of the spade rudder location, as well as undrilled molded areas at the top of the trailing edge of the keel that appears to be a place through which a keel-hung rudderpost might pass. Outward hull flange, boltholes through hull where chainplates might have once been installed. Deck and all interior structure removed and not in evidence. The boat has an outboard cutout in the counter, and several through hull fittings.
On the off chance that this design might ring a bell with anyone here, well...here it is.
Click here for more photos of the hull.
Feel free to shoot out ideas. We know pretty much what it's not, but don't mind even incorrect stabs at it.
Dave says the hull is probably destined for the dumpster soon.
