Just placed an order for this. Anyone have experience with the grades and types of Festool abrasives that apply to boatwork?
Thanks in advance,
Festool Rotex RO 150 FEQ Dual-mode Sander
boatsnh
- Boat Name: IRIS
festool rotex paper
Hi David,
I bought the 5" model 1 1/2 years ago when I was repairing my cabin & the entry bulkhead. I got the 5" size since I already have the 5 finish sander & wanted to only keep a single size paper in stock. Also thought I could get the 5 inch size in more weird little spaces - seems to work. I find Festool paper is very good & an ok price for what you get - They have a pretty gcomprehensive list of grades/packings . Honestly you can follow the "cut sheet" guidelines pretty closely. I found the Safir paper to be the sharpest for glass removal - I think I used 36 grit on "rotary" and it worked pretty well. Cleaned up with Safir 80 grit on random.
I find the papers for Paint/wood to actually last better for the named application - they tend not to clog too much. I use the rubin & brilliant ( 120 grit & 220 grit) All in all I've been pleased with the machine. I love the vacuum system - sometimes it might be a bit slower than a die grinder or the 'ole' 7 inch body grinder but I'm not cleaning up the whole darn boat after each use - well worth keeping glass ffibers out of me and the boat - Also, the paper lasts a pretty long time. All in all Iv'e probably run thru a few hundred bits of paper - in 50 or 100/boxes.
Mike
Mike
Re: Festool Rotex RO 150 FEQ Dual-mode Sander
David wrote:Just placed an order for this. Anyone have experience with the grades and types of Festool abrasives that apply to boatwork?
Thanks in advance,
I think I am using brillant and crystal for plastic and paint they cut nice, all of there paper is great and rubuen for wood
tim
