Spreading thickedned epoxy
Tools you like...tools you hate...
Post by David »
Tim,
Would you share with us any tools you've found useful in spreading larger amounts of thickened epoxy?
thanks,
Assuming you mean spreading it relatively thinly and evenly across wide areas (like hulls and decks), I find it hard to beat a selection of drywall knives. I normally use a good 6" knife, but occasionally use up to 12" in certain instances.
I find the 6" to be the most versatile and effective, though, even on wide expanses.
During the cockpit work I became a huge fan of the ziploc-bag-with-clipped-corner.
Boat Name: Quetzal
Post by Quetzalsailor »
For large expanses I use a variety of tile adhesive type notched trowels. Wet out with neat epoxy, first. You get good control of quantity. Not my idea, it's right out of Gougeon's book. For small stuff, I use one of my pre-prepared stir sticks. These are rips of 5/4 decking, 1/8" x 10" or so, ground square or to the radius du jour.
When the epoxy cures, grind them clean for reuse.
Post by David »
I used a slection of drywall knives too. Also silicone kitchen mixing bowls which clean up very easily.
Wood Whisperer
Post by CharlieJ »
also- most auto parts stores sell plastic squeegees, in assorted sizes. I often use them, and wash 'em down afterwards- or not- often they'll bend and pop the epoxy back off. If the edge gets a bit rough, a smoothing on some 150 grit works fine.
When I'm fiberglassing a hull I'm building, the squeegee is my preferred tool for wet out, even on the sides of the boat..
meubcr
Post by meubcr »
I'm a big fan of the plastic drywall knives also. They are sufficiently flexible to allow for a slight convex shape to the fairing compound. With careful cleaning, I can get 5 applications before the acetone pits the knives' edges. I usually use a paint stir stick or tongue depressor to get the basic shmear, then use a single pass with the knife to get a smooth finish and defined edges to minimize future sanding.
Post by David »
Try vinegar instead of acetone. I keep an open tub of vinegar and drop my only half cleaned stirring sticks, squeegees, knives, etc in it. The vinegar even softens old hardened epoxy.
