I know there was a recent short discussion on this when Tim was doing the daysailor interior, but I thought it merited a bigger discussion.
I recently did a search for the right device to strike water lines and such and was displeased with most of the device specs for one reason or another. (Coming from a surveying and electrical engineering background, I'm picky!) I ended up buying the Porter Cable / Robotoolz Model RT-7610-5 from Coastal Tool (www.coastaltool.com) for $159.00. It also came with an additional torpedo laser level on their current promo. The several reasons I wanted this model were:
1) to use it with my Slik camera tripod. The tripod has a 1/4"-20 adapter and the level adapter has a sleeve designed for 1/4"-20 although I had to tap it after receiving the device. The tripod has a "crank-up", lockable center column so I can set the tripod close to the desired height and finely adjust the laser line with the crank. Surveyors' tripods are 5/8" - 11 thread and don't have the easy vertical adjustment feature.
2) The level has a free hanging mirror so as long as I'm within about 4 degrees of level, it will level itself and blinks if it can't achieve level.
I just finished using it to strike the waterline on a 19' Boston Whaler Outrage, (sorry folks, my kids made me do it), and I achieved closure within 1/16" after setting up in three locations.
I chose not to get one of the rotary motor devices because they aren't much good for anything else. This one is five beam with vertical, horizontal and 90 degrees.
Laser Levels
JetStream
- Boat Name: Sojourn
- Boat Type: Pearson 27
Laser Levels
Bruce
