Had an old spreader:
Drilled a few holes:
Fastened to the backstay. Attached the main halyard to the old spreader and tied the bitter end to the bottom to form a continous loop:
Ran it up the backstay but it wasn't high enough, just toched the bottom of the windvane:
So, I drilled another hole in the old spreader just a little lower. This time it moved the windvane but it sprang most of the way back:
So, I drilled another hole even lower and ran it up again. I compensated for the spring back but, it didn't! Now it was bent just as bad as before but up instead of down:
I decided to make a hook from a bolt and try to get it back down:
It worked:
My wife, who was predecting failure during the whole process, was impressed!
Jack
