Hey Tim,
What is your source for those foamy sanding blocks you were raving about? I just realized I am going to need one soon.
Those foamy sanding blocks
What we're talking about here is the 2-3/4" x 5" soft hand sanding block by 3M. I just used one of these for hand-sanding the Alexseal primer on hull and deck and wonder how I got along without it all this time.
You can get these at Jamestown Distributors, among others, for $13.00.
3M Soft Hand Sanding Block
There is also a firm version with the same shape. Both use the standard Stikit sandpaper rolls.
If you ever do any hand sanding, then run, don't walk, to your nearest distrubuter and get this set up.
