respirator parts
respirator parts
I was really looking forward to doing some intensive grinding on the interior today but when I dusted off my respirator I noticed the little valves (inhalation particularly)are looking pretty bad. This respirator is advertised as having replaceable parts but I can't find them anywhere.
Does anyone have a lead on 3M 6000 series full face respirator parts?
Britton, those inhalation valves aren't really a precision operation. As long as MOST of your exhaled breath goes out the other valves, they're working fine. The important valve is the exhalation valve. If unfiltered air is leaking in through that one, it's an issue obviously.
Can you taste the dust through the mask?
I think the primary purpose of the inhalation valve is to prevent exhaled moisture from affecting the filter element.
No, the mask "tastes" like it is working correctly. I did try it today and it seemed okay with the vacuum sander but I need the 8" pad on the grinder and I didn't think the mask was up to the task.Can you taste the dust through the mask?
I did notice the mask was fogging up easily which with the low light levels became rather frustrating.
If the inhalation valves aren't too high tech maybe I will try something I read about a while back. I think I read that you can put soft rubber in the microwave to make it pliable again. It seems mine sat for a season and began curling up and now they won't lie flat. It definitely needs a tear down and a thorough cleaning. I think I have some green stuff growing in there...
Thanks.
Britton,
At the marina/yard where I work, we get our 3M respirator parts from a local auto-body supplier - along with many other 3M items such as sandpapers, tape, etc. Funny, I just ordered some of those exhalation valves a few days ago.
Now you probably don't need to order your parts from Minnesota, but you might try an auto body supply locally.
Or, if you really can't find what you need, I can get you parts and send them along.
--- Rachel
PS Don't try to dry a cat in there either ;-)
--- Rachel
hehe...well, I guess "melted" might be the ultimate definition of "pliable"!bcooke wrote:Bad, bad, BAD idea...I think I read that you can put soft rubber in the microwave to make it pliable again.
Who would have thought the rubber would melt into the plastic plate?
Anyone know where I can get some replacement parts for a respirator?...
-B.
Maybe if you'd thought you'd read further along, you might have seen someone else's similar unfortunate result as well!
Now you really need those replacement parts.
Next time try a little swab of vaseline or sometimes "Armor All" does the trick
Why does the best advice always come too late?The best way to make old rubber softer and more pliable is to soak it in warm water with a little liquid dish soap. Give it a rinse when you are done.
oh man that's too funny!
This isn't the sympathy I was looking for...PS Don't try to dry a cat in there either ;-)
-B.
I've no idea. I hadn't noticed it until you pointed it out.
Time to pull my head out, eh?
"Master" may be a bit much, however. "Enthusiast of the Arcane", certainly, but I don't know if one can master the arcane any more than one can master sailing. The beauty of the whole moving target thing. =)
Yeah, I suppose we might have related the rubber-softening techniques earlier. Like Tim always says.... the advice around here is worth what you pay for it!
Of course, Britton, if you post here and then immediately head to the microwave with respirator (or cat) in hand, you're likely to miss the advice, since we're not all sitting here just waiting, hoping, for a chance to respond to you! hehebcooke wrote:Why does the best advice always come too late?
Patience is a virtue. (I keep telling myself that so that maybe one day I'll actually follow that advice too!)
What Do you people do here then?...Tim wrote:Of course, Britton, if you post here and then immediately head to the microwave with respirator (or cat) in hand, you're likely to miss the advice, since we're not all sitting here just waiting, hoping, for a chance to respond to you! hehe
Actually, in the time it took to conduct my brave, if stupid, experiment, Mike had posted a reply, which, had I heeded, would have allowed me to do some intensive grinding today. Instead I will make some phone calls and order some more materials... Anyone want to buy my spare kidney?
Now instead of waiting a day to get my respirator back in action, I will wait a week. Maybe someday I will learn. Probably not though...Patience is a virtue.
Well, after an intensive search I found them here:
http://www.fastenal.com/web/home.ex
I had to buy them in industrial quantities though so I should be good for many, many years...
We have a 3M dealer who comes through the yard every week with a trailer-full of 3M (and other) marine supplies. I approached him back at the beginning of November looking for the same little valves. Unfortunately, he was unable to get them due to FEMA's needs in the New Orleans and costal Mississippi areas. He finally got me some 2 weeks ago.
Doug
http://heartofgoldsails.com
Karen Blixen
Karen Blixen
On a similar note, we recently got notice from 3M (at the marina/yard where I work) that they anticipate possible shortages of respirators due to people buying them en-masse as protection against bird flu.
The memo also mentioned that "they" (if I remember correctly, a governmental agency) would be investigating any large purchases of respirators or parts (beyond any typical ordering amounts) to guard against hoarding.
Somewhat unnerving.
--- R.
Somewhat unnerving.
--- R.
Yikes. I think I'll take my chances, rather than living in a respirator.Rachel wrote: they anticipate possible shortages of respirators due to people buying them en-masse as protection against bird flu.
I heard a soundbite from an epidemiologist to the effect of "money spent on air filtration, flu shots, and other security-blanket type efforts would be far more effectively spent on something that would actually improve one's health, such as membership at a health club".
Yeah, but I can wear my respirator while sitting on the couch watching law&order reruns!
You mean to tell me that these repirators can actually block airborne virus'? Sounds rather misguided to me. The virus would probably be happy to sit on the surface of the mask and then pop into your mouth the first time you lifted it for a bite to eat anyway. I saw (and read) "Hotzone"a few years ago and the suits/breathing apparatus they were using to combat virus' did not look like a 3M 6000 series at all.
Now, I could imagine with all the demolition going on in the Gulf Coast that 3M might be selling lots of regulators right now.
I had a moment like that last winter when some wise guy cut two circles of plastic and insterted them underneath the filter cartridges...
Since I know everyone is in suspence to know when I will be getting back to my grinding...
After three weeks I finally got a call from my supplier to say that the parts had come in. One of their outlets in Texas had them on the shelf.
Turns out my supplier has bad data in their computer system so the parts that were shipped were of the wrong quantity and wrong type. After a long chat it was determined that it was their system at fault and now I will find out in a couple of days if they can even get them. According to a couple of suppliers I have talked with (I am becoming very well known among the industrial suppliers in the area) 3M will only ship these respirator parts in enormous quantities and none of the suppliers wants to get stuck with a 10,000 little rubber intake valves.
From a lost productivity point of view tossing out the respirator and buying a new one would have been far cheaper. I thought I was being wise and frugal with those $1 parts. I compensated by purchasing $800 worth of insulation for the hull and leaving a $700 deposit on some custom stainless steel water/waste tanks. I feel much better now.
Moral of this story. Desite the sales rhetoric. It might be better to consider those 3M respirators disposable; just toss 'em and buy a new one when those flimsy (non microwaveable) parts wear out. Parts are tough to come by and lost productivity is expensive. Of course as long as the temperatures are under 10 degrees and wind is blowing 20+ knots I don't really mind an excuse to avoid the boatyard...
