can anyone suggest a source and brand fo a 50 w panel ,w/controller ?new or used
solar panels
Surveyor
- Boat Type: Alberg 30 #329
Re: solar panels
Check out this outfit: http://www.sunelec.com/
You might call them to be sure your getting the right panel/controller combination.
Jim - Bahala Na!
http://svcookie.blogspot.com/
- Chris Campbell
- Boat Name: Luna
- Boat Type: Yankee 30
Re: solar panels
Try Craigslist or Kijiji (depending on where you are and which of the two is dominant) - I'm sure there are lots available. Solar panels are great, and durable - who makes it isn't all that important, since they're all quite good. Polymorphous panels have lower output per square inch, which is a drag, so polycrystaline or monocrystaline panels are better, but whatever you decide on you'll get long life out of it.
