It uses FREE raster and Vector charts which you can download from the NOAA. I use the free trial occassionally (if I used it regularly I would buy it) for mapping routes on the PC, validating my bearings between points and noting distances etc. I also use it to make up point to point routes which I print and file for reference.
Below are some screen shots I took to illustrate, showing both vector and Raster charts :
