Spinnaker pole fittings- Alden Challenger
I'm about to start building a wood pole by laminating up some clear spruce but as my better half pointed out may be I should find some end fitting before all the work is started. The specs from Alden call for a Merriman size 3-A, fig 450-L. I don't have exact measurements yet but I think the socket that slides over the end of the pole is around 2-3". I'd love to find some bronze ones but can only find smaller ones. I've been calling consignment stores as well (Wickford, RI) but think there must be some kicking around a spar shed some where. Any thoughts, ideas?
Re: Spinnaker pole fittings- Alden Challenger
I would listen her.JSmith wrote:I'm about to start building a wood pole by laminating up some clear spruce but as my better half pointed out may be I should find some end fitting before all the work is started.
Are you asking for sources? Or for specs?
- Bluenose
- Boat Name: Bolero
I would second this advice. I have been looking on and off for for quite a while and they seem quite rare. Maybe in the North East you will have better luck. The only suggestion I could add is to place some adds looking for a wooden spinnaker pole. It might be the best way to find old bronze end fitting.Hirilondë wrote:I would listen her.JSmith wrote:I'm about to start building a wood pole by laminating up some clear spruce but as my better half pointed out may be I should find some end fitting before all the work is started.
Good Luck
And if you happen to find a pair of fitting a bit too small, say 1/2-2 inches, I will gladly take them off your hands:).
