Release fabrics what do you use?
Commander-147
- Boat Name: Destiny
- Boat Type: Pearson Commander
Some people tell me they use mylar for applications where you do not want epoxy or polyester resin to bond such as a backer plate for a hull repair or fabricating frp panels. Others have told me they use visqueen. What is the best thing to use and where do I buy it and how much does it cost?
Jerry Carpenter
Commander # 147 "Destiny"
Oscar
- Boat Name: Lady Kay IV
Re: Release fabrics what do you use?
I use kitchen cellophane wrap...... or packing cellophane wrap (a little heavier).
Plastic drop cloth works pretty well too.
kabauze
- Boat Name: Nevermind
I use two things depending on the job:
1) PVA. Brush on two or three coats and let dry, and you magically have a plastic film covering the part/plate/whatever. Dried PVA films are just like green Saran-Wrap except that they dissolve in water!
2) 100% polyester taffeta from the craft or fabric store. Swoop into the fabric store with macho swagger. They'll have tightly woven polyester (taffeta). Out here in California it's usually $6 a yard in the 54" width. Pink seems to work best. The polyester taffeta is very similar to Peel-Ply, a commercial product intended for the same use (see http://www.aircraftspruce.com/catalog/c ... eelply.php ). Dacron is polyester.
