Lessons learned
Boat Name: Jenny
Lessons learned
Post by bcooke »
I learned an important lesson today.
No, not that lesson...
I learned the value of mocking up all parts before permanent ones are manufactured. Partly because I have a hard time visualizing all the bits and pieces of connecting hardware and conceiving parts in their three dimensions and partly because one of the few things I can afford is a single sheet of 1/4 luan plywood,... I made some mock-ups of tanks I want to install in my boat.
One of these tanks was a replacement for the normal Triton water tank under the V-berth. I couldn't understand why the tank wasn't built right up to the underside of the berth which would increase capacity considerably in an otherwise wasted space. The tank I had mocked up looked just like the original tank but taller and wider but still fitting into the fore and aft space formerly occupied by the original tank. Everything looked good. I left it in place for a couple of weeks while I sorted out the rest of the plumbing and figured out where the connecting hoses would be routed and so on.
Anyway... Today, it was time to take the dimensions of the mock-up down to a local welder who can get me a good deal on a custom made tank. I started removing the mock-up which had been built in place only to discover something very important. It wouldn't fit out past the bulkheads. I had to tear it apart to remove it from the V-berth area. Had I gone with my orginal plan of just measuring and ordering the tank I would have had a very nice, if unused, V shaped tank to hang on my basement wall.
Long story, short lesson. Taking the time to make a mock-up of your intended design is time well spent.
That would have been a painful mistake!
dkall
Not really...
Post by dkall »
You could have made a key hole passage to the forward stateroom. Of course you would then have problems makeing a door to fit. :) But isn't it always so, you fix one problem and create another. :) Good luck.
Dave-Westsail 42-Elysium
Boat Name: Jenny
Post by bcooke »
Yeah, I may have missed a golden opportunity to tear out those crooked bulkheads while making room for my 40 gallon water tank.
Wood Whisperer
Post by CharlieJ »
LOL- a second value that many don't realise about full sized patterns- If ya can't get the pattern OUT, ya can't get the part IN.:)
Glad you mocked it up first.
