A really nice feature of this setup is that the chart corrections can be downloaded for free on a weekly basis from NOAA, so that charts can be kept current at no cost, something most high cost chartplotters don't support.
Challenger949L wrote:Would the gps receiver, being in the cabin, cause any problem with it picking up signals?
Probably not.
Large amounts of concrete are a problem, as is smaller amounts of steel, but the structure of a boat cabin, especially a fiberglass boat, are not likely to cause even a small issue. With a modern receiver - less than two-three years old - the chances of a problem are even lower.
Aren't units intended for mounting (like the one pictured) generally configured for external antennae? I know the one on my father's boat has an external.
I've never tried to use my handheld from inside the cabin.
On my race boat, however, the "navigator" sometimes finds the cockpit a bit crowded, and seeks refuge in the cabin. He plugs an external antenna into his superduper garmin handheld and suction-cups it to the outside of the coachroof.
I think it works without the external, but it's more accurate with the external because it "sees" more satellites, or something like that.
