Photo tip
JonnyBoats
Photo tip
Post by JonnyBoats »
With digital cameras and computers it is easy to take and keep photos to document our boats. If you are like me, a photo of a nut is not enough to show me what size wrench I need to loosen it.
This gave me the idea of putting a wrench on the nut or fitting when taking the photo.
Below is a photo of my water lift muffler with the drain plug which needs to be loosened to let the water out when the boat is hauled for the winter. Now before I start crawling into the cockpit locker and standing on my head I wouln't have to drag lots of wrenches with me "just in case".
John Tarbox
http://www.boatmaine.us
Someday, it'd be nice if someone would build an entire structure or mechanism that used only one size nut. Something to strive for.
JonnyBoats
For a start, wouldn't it be great if someone built a boat that only had metric or SAE fasteners, not both?
John Tarbox
A30_John
Post by A30_John »
We'd still choose the wrong size wrench. ;-)
Great idea for taking the picture, BTW..
John
Mark.Wilme
Post by Mark.Wilme »
Speakng as someone who grew up in the UK with 4 different gauges (Metric, SAE, Whitworth and Imperial) I can say that 2 is MUCH better than 4.
feetup
Almost a Finish Carpenter
photo tip
Post by feetup »
My father has spent a lifetime making incredibly detailed scale models and he always sets a one inch wide tape measure in the photos of the full scale pieces he is trying to model. Even at a distance the one foot markings are clearly visible and in the closeups the inches are clear. He measures the graduations on the tape with a dial caliper, and the dimension of any specific piece in the same plane and using ratio and proportion with simple algibra, cross multiplies a result. I.E. if one inch measures 0.375" and the piece you are trying to dimension measures 1.031" then it would be 2 3/4" etc.
Feetup
