I know there's information somewhere on this, but I searched here and on the tritonclass.org website and couldn't find it.
When you're having a Triton hauled out with a travel lift, where is the best location for the aft strap? You want to avoid having it under the false keel, right?
I've only had the boat hauled once, and if I remember correctly, the aft strap was under lead, just foreward of the false keel. But I think I've read that it can go under the counter, slipped between the top of the rudder and the hull.
I keep thinking that if the aft strap is under the keel, right before the false keel starts, then the block will have to be even farther forward. But, if you put the strap under the counter, then the aft block can be under the lead keel but as far aft as possible.
Thanks in advance for your thoughts. (I've come too far to break something now, or have the boat fall out of the straps!)
Jay
Strap Location for Haul Out
triton318
- Boat Name: Dove
Jay
Dove, Pearson Triton #318
Hayes, VA
Hayes, VA
I block my Renegade under the keel in 2 locations. One of them is hollow inside. By putting in a drain plug I found the glass to be 3/4"-7/8" thick. This alone shouldn't be any criteria regarding Tritons, but I bet the Triton's "false" keel to be quite strong.
That's not a bet I would take. Triton "false keels" are notorious for being weak, thin, and poorly constructed in general; as with all things, the actual conditions vary from boat to boat. This thing is unlike any other construction in the Pearson repertoire (thankfully they seem to have learned their lesson). Until you know the condition of your own, assume it to be weak, and avoid blocking beneath it if you can. And plan on reinforcing it when you haul out so that you don't have to worry about this going forward.
If you have to lift the boat in a Travelift, it may be best to keep the strap at the very heel of the keel. Some people place the aft strap on the counter, but most yards think this is very odd and won't do it despite your admonitions. I don't see how you could lift with the aft strap as far forward as the end of the lead; there'd be too much boat behind it to properly balance. But the boat will sit nicely on two sets of blocking placed only beneath the lead, with the entire false keel hanging out in the air.
Some false keel photos:
This is what mine looked like (before I repaired and strengthened it):
This damage occurred to another boat when the boat hauler placed beams beneath the false keel to support it on a trailer:
This unique view highlights how flimsy some of the false keel construction can be.
I coulda gone my whole life without seeing that last picture...
Yikes!
Yikes!
- gone2ddogs
- Boat Name: Silver Girl
danielguiod
- Boat Name: HOKAHEY
Re: Strap Location for Haul Out
When we launched HOKAHEY in the spring. The straps were tied 6' 8" apart and it picked beautifully. The aft strap was just aft of the lead. This is still a very strong point for lifting, and you can block just forward of it on the lead. This puts the aft strap at the aft big portlight, and the forward strap at the aft little port.
When we pulled it out today, we had a different operator, bad attitude, and things didn't go so smoothly.
But, in the end it was OK.
My pics are too big for the forum, but I will email them if anyone wants them.
TritonSean
- Boat Name: Jenny Marie, #308
- Boat Type: 1963 Pearson Triton
this year the aft strap got up between the rudder and the keel. that was not fun !
no apparent damage though.
I like under the counter for the aft strap. seems to work.
