Stern Tube
kowens
Boat Name: Dragonfly
Stern Tube
Post by kowens »
Hi.
My Triton has a cracked fiberglass stern tube. Multiple cracks radiate forward from the aft end of the tube. The longest I have found yet penetrates forward of the deadwood into the tube about an inch. Some seem to have been caused by the cutlass bearing set screws being cranked down on a bearing without dimples. The cutlass bearing easily spins in the tube probably from rotating with the shaft.
I don't know if its the original tube. It's 2 inch OD and 1.5 inch ID. The boat was re-powered with a Yanmar 2gm20f before I purchased her. Being a newbie, I wanted to ask, Is it safe to repair such damage or should I replace the entire tube?
Thanks for any advise,
Ken.
Re: Stern Tube
I'm not an engine guy but if the tube is not falling apart or leaking into the bilge you should be able to add some fiberglass around the outside of the tube and around the hull to strengthen it. Then check the shaft alignment is not causing vibration. Maybe someone else with more engine experience can tell you more about it.
hansjthomas
Boat Name: Solitude
Re: Stern Tube
Post by hansjthomas »
Ken
What did you end up doing with your stern tube?
Hans
Re: Stern Tube
Since it was no longer needed I cut the tube off flush on the outside and plugged both ends with a wood plug and thickened epoxy and glassed in the prop aperture. I'd have done something less permanent if there was any chance at all that it would be needed again. But you have an inboard engine so that doesn't apply.
hansjthomas
Boat Name: Solitude
Re: Stern Tube
The fewer holes the better!
