I have a dwyer mast hinge. It comes with 4 holes in the bottom to attach to the boat.
I was thinking of using 5/16 stainless rod couplings glassed into the topside to bolt the hinge to. Or purchase 4 of dwyer spacer nuts and use them. Is this over kill?
Thanks in advance
Mike
Mounting a Dwyer Mast hindge to the topsideon an Albin vega
Redwood1957
- Boat Name: Prayer
- Boat Type: Albin vega
Re: Mounting a Dwyer Mast hindge to the topsideon an Albin vega
It may be strong enough as is but I would install compression nuts or sleeves of whatever type so that the vertical weight will be transferred to the step by the nuts instead of putting all the load on the plate and pins.
Redwood1957
- Boat Name: Prayer
Yes the hindge came with those nuts. I am looking at using their organizer plate on the bottom then the hindge wih 3 nuts then my plate that was used .
My photo is to large. Any ideas how I would save a photo to post.thank you Mike
Redwood1957
- Boat Name: Prayer
I posted photo I will drill hout holes so all is flush.
