Spreader thumbs
Posted: Tue Apr 10, 2007 9:27 pm
Well, what do you call them, then?
The half-cleat thing on the spreaders that prevent halyards from slapslapslapping the mast while at rest. Spreader thumbs.
I've been doing the "sling 'em 'round the spreader end" thing, but it's bad for the rig, looks awful, and the leather spreader boots are starting to show ill effects. I'd like to lay some thumbs on my spreaders, which are the wide-flat aluminum type. Something quick and simple.
Any ideas? Any tips on optimum position, etc?
Posted: Wed Oct 31, 2007 3:33 pm
by Zach
(Thread dredge)
Did some searching around... Cool idea! I'm tired of launching bungee cords over the side!
Thumb cleats. (Did some reading, evidently they used them everywhere on old gaff rigs and thames barges.)
Hook side out, grabs hold of the halyard and holds it out far.
I'm thinking a nylon shroud cleat and a larger U-bolt would yield the same results... My spreaders are metal tubes. Saw off the pointy end, and leave the round loop.
Don't have a clue as to how bad they'd snag battens, and if it'd catch an overlapping jib when tacking. Gut feeling is that 6-8 inches off the mast would be plenty to put some tension on the halyard.
Posted: Thu Nov 01, 2007 9:29 am
by keelbolts
Small stuff with a bowline & a midshipman's hitch works like a champ, won't shoot over the side, won't snag anything, and (perhaps my favorite) is SIMPLE. I work part-time at West Marine & I'm always amazed at the stuff people will buy to do what a knot or a one cent piece of rope will do. Also, a piece rope is a "multi-tasker" as you can use it in a number of applications.
Daggybits
Posted: Thu Nov 01, 2007 11:50 am
by jollyboat
I have ash shroud rollers on 466 and so have opted to daggybits tied to my turn buckes to lead and secure halyards away from the mast while moored. I have opted to remove as many cleats and what would otherwise make 466 much easier to use (and sensible) so I have had to resort to creative ways to secure both lines and the boat while moored.
Posted: Fri Nov 02, 2007 7:32 pm
by Capn_Tom
How bout some belaying pins?
