This is what the new (used) mast looks like:
As for fitting it out...all the standing rigging will be new. I have a set of jumpers, but they are toasted. The main I have is in good shape, the jibs I have will work as the staysail/spitfire, and their configuration will not change as the stay will go to the orginal stem location. I'm thinking that I can use the shorter main for a while until I get a new one and then use it as a backup.
So, my question are:
1. Should I leave the mast 39' (as it is now) or cut it down to the 38' height I have on the boat now?
2. Any thoughts on using the double spreader arrangement the mast is now set up with?
3. What about the jumpers?
4. I am planning on removing the plastic mast base and machining a piece of billet aluminium to replace it. I'm thinking this would be a better way to attach the mast base to the hinged mast step?
As always, any thoughts and feedback are appreciated.
Triton 185
