Hull mounted chain plates
Vince124
Boat Name: Phoenix
Boat Type: Contessa 26
Post by Vince124 »
For those of you that have done this mod... did you find any noticeable difference in tacking angle?
Re: Hull mounted chain plates
I have a 28' Triton with original inboard shroud chain plates and in the slip next to me is a Triton with external chain plates. The externals attach about 3" farther outboard. I'm not great with math but seems to translate to about 1.5-2 degrees on the sheeting angle. After sailing on both boats I can't tell a difference but maybe a racer would notice it.
Vince124
Boat Name: Phoenix
Post by Vince124 »
Thanks. I'm not a racer, but I am keeping this possible modification in mind for the future. The deck core around my chain plates is protected, but an occasional leak through the silicone bedding will pop up sometimes.
Silicone is not the best choice for chain plates. Polysulfide Life-caulk should last longer but even that can leak after a couple years. I've found it best to use Bed-it butyl under the cover plates.
Vince124
Boat Name: Phoenix
Post by Vince124 »
Definitely agree with all of those points. These boats don't have factory cover plates, but it's on the list to fabricate. Thanks Jim.
