Deep cycle batteries
Sailor Simon
- Boat Name: AURORA
- Boat Type: Swiftsure 33
Who makes reasonably priced reasonably reliable and reasonably long life deep cycle marine batteries? I used Canadian tire brand Nautilus Deep Cycle several years ago and never had a concern. I have the physical space for 3 house batteries and one cranker. I will be running a small freezer/fridge, charging a computer, playing the radio etc... evening fans in the berths and various mooring/steaming lights on a 33' sailboat. Sailpr Simon
sscoll
- Boat Name: Medora Jane
Re: Deep cycle batteries
Look at Trojan batteries, assuming you're talking lead acid. How they perform is 100% up to you. My last string lasted seven years but I probably should have switched them after six. They're not cheap but are well built. I can't help with suggestions regarding gel cell. I've no experience with them.
Good luck.
Steve
Good luck.
Steve
I have two 6 volt Trojan T-105s in series which makes a 225 AH house bank, and a separate 12 volt cranking battery the for the engine. My Trojan T105s are 6 years old and still going strong. All batteries must be properly cared for to get max life from them. I have a dockmate who has four T105s that are 11 years old.
mitiempo
- Boat Name: Mi Tiempo
Flooded batteries are the best value and I agree the Trojan T105 are a good choice. Not sure where you are but Exide GC2 are comparable to Trojan but should be less expensive if available near you.
These are 6 volt so you will need 2 or 4 in a 12 volt bank. Starting can be taken care of with a 12 volt battery.
It is also a good time to look at your charging system and possibly upgrade.
