Alberg 30 Trailer project
Cruiser2B
- Boat Name: Salacia
- Boat Type: Alberg 30
Needed a trailer to get my Alberg 30 home for a refit. I tried doing the v berth in the marina and just wasn't able to get it done, too hot, too cold, good sailing weather....anyway just too many distractions to work on the boat while in the water. So I decide to take her out and bring her home. Called a few places and to get her home was going to run $1000 each way plus hauling out fees....what? 15miles.... I just figured it would be money wasted. I wanted to invest in a trailer, Price tag near $5-6,000....yikes. Next option build one. I decided to look around for something used that I could modify. Here what I ended up with for $900 28ft trailer, 2-6000lb axles built for a chesapeake deadrise. It is made of heavy duty material. All I have to do it make it work for a sailboat... So far, here what I've got
Weather turned cold again, snowed today...supposed to warm up again...look for updates or check out progress on our blog
www.svsalacia.blogspot.com
Preparing to get underway!!
TampaBay
- Boat Type: Coronado 15
Re: Alberg 30 Trailer project
Do you have a welder?
Cruiser2B
yes, 3 in fact....Lincoln 135(110V) unit, which i am using in my yard to tack additional mods on trailer. I have a Lincoln pro Tig 175 for smaller project, stainless work and smaller gauge stuff and a Lincoln power mig 255, heavy duty welder... which I will use on the trailer to complete all the final welding. I keep that at a friends garage because we can do larger projects there. I hope to get the trailer out to his property in the next week...if I can ever finish getting it marked up...25 degrees here today....
if you look close in the pics you can see the gas bottle and small portion of welder
Cruiser2B
Made some progress today,here is a pick of one of the hull supports..... view my blog for all picks
http://www.svsalacia.blogspot.com/2014/ ... eport.html
Cruiser2B
As she sits now, snow on the way...so prolly not much progress this coming week.
going to get fenders tomorrow.
Crazer
- Boat Name: Clio
Looking good! Great project, thanks for sharing your progress.
As eccentric as my boat.
Rhodes Swiftsure 33
SV Clio
Rhodes Swiftsure 33
SV Clio
Cruiser2B
Thanks Crazer,
Order a new coupler Monday, 12,500lb bull dog....still hasn't arrived yet(from NC to VA.....HMMM)....and then this wet weather has turned my yard into a small pond.....so not much will get done on the trailer this weekend I am afraid. I may take wheels and hubs off and repack the bearings. Oh well...I will find something to do
Cruiser2B
Here is a link to more of the Alberg 30 trailer build. Installed a new tongue and coupler....I promise many boat projects will follow
http://www.svsalacia.blogspot.com/2014/ ... inues.html
TampaBay
What was so wrong with those hubs that you had to replace them?
Cruiser2B
I decided to put brake on the trailer. Originally I was not going to.... I am only moving boat a few miles. I just worried about the what if's too much. So as I started to recondition the drums. I just decided they were too far gone for new brakes. I just decided to replace them.TampaBay wrote:What was so wrong with those hubs that you had to replace them?
here is a link to progress this week.
http://svsalacia.blogspot.com/2014/03/what-gives.html
Cruiser2B
Cruiser2B
Got some new rubber on the trailer. Weather was pretty crappy all weekend but sun is shining now. Looks like I should get some good progress this week. Hope to finish the trailer up real soon.
Cruiser2B
Warmer weather is upon us here in Virginia. I have been able to get out everyday this week and chip away at the trailer...Soon there will be a sailboat on it and in my posts!
Here is what is looks like now:
http://www.svsalacia.blogspot.com/2014/ ... lmost.html
TampaBay
That wheel and hub combo is interesting. I haven't seen that type before.
TampaBay
When you put the hub back into the wheel, how are you sure that it's all perfectly round?
Cruiser2B
These are old dexter axles, common uses were mobile homes and low boy construction type trailers. They have a 6000lb rating, the tires I bought are 14ply load range GTampaBay wrote:That wheel and hub combo is interesting. I haven't seen that type before.
You may not be able to notice from pictures but there is a notch if you will on the face/edge of the five fingers of the hub. The rim fits perfectly into those notches basically centering the rim as you tight the lugs. They are known as dismountable rims and tire size is 8x14.5. Not too sure if they are used in new production stuff anymore but parts are still readily available. The tires were a bit hard to find locally, but showed up everywhere on internet. I was able to find them locally but paid a bit more($15 a tire) for them.TampaBay wrote:When you put the hub back into the wheel, how are you sure that it's all perfectly round?
hope that helps
Jason
Cruiser2B
Cruiser2B
I admit, in the beginning I thought you were absolutely nuts on this one.
Good job.
Good job.
Cruiser2B
