I would like to secure my 4 cabin floorboards and need suggestions on the best hardware and method to use. My A30 is a MK2 so it has the fiberglass liner and the boards are simply held by gravity over the floor pans. The one at the aft end covers 2 batteries.
Alberg 30 cabin floorboards
- Boat Name: Alegría
- Boat Type: Alberg 30
Re: Alberg 30 cabin floorboards
You can see how I've done it near the end of the following video using a metal plate at one end and a latch at the other. With your liner you may have to modify the wood and fiberglass to accept the latch. Another simple and cheap method instead of the latch if you find that doesn't work in your situation is to use a metal plate that swivels on one thru-bolt so that you turn it to hold down the access board and turn it the other way to open.
https://www.youtube.com/watch?v=rcLT_S9489E
The latches look great! How did you cut the top of the boards to accept the latches. Did you use a chisel or router? The boards on mine are made of plywood.
I used a router then a chisel to square up the corners. An oscillating cutting tools can work instead of the chisel but I find it hard to control accurately in corners.
