Swing out depth sounder bracket
Summersdawn
Post by Summersdawn »
Hi Peter,
Here are some shots of the depth sounder bracket I made. It was made out of scrap stainless steel (lid of a broken alcohol stove), and some scrounged teak (broken autohelm bracket).
It is basically an oval shaped piece of stainless with 3 holes drilled in the bottom an one in the top. I bent the top and bottom 90 degrees. It is mounted on a piece of teak, which is attached to the rear bulkhead, just off to the side of the companionway. The arm itself is a piece of teak, with stainless strips on the top and bottom. I used some threaded stainless rod as the hinge point - it goes through the top of the bracket, the arm, and then the bottom. There is a little vertical slack in this. On the bottom of the arm is a pin - this pin fits in the 2 holes in the bottom to lock it in place (one for the folded in position, one for the extended out position).
Here are some photos:
It is a pretty simple design, and could easily be adapted to better suit a particular boat, or the material on hand. It would have looked really good with brass/bronze instead of stainless steel, but that would have required constant polishing. Aluminum would have also made a good choice. Since the wood is inside your boat most the time, you could use whatever type of wood you have inside your boat, or you could use spruce/pine/fir or whatever and paint it.
Rick
Summer's Dawn
24 San Juan #380
Peter
Boat Name: Pagan
Boat Type: Albin Ballad 30
Post by Peter »
Rick:
Nice job! That's exactly the kind of idea I need to adapt to mine ... and the price is right, too.
Thanks!
Peter
Victoria BC Canada
Albin Ballad 30
MQMurphy
Topside Painter
Boat Name: Ikey Boy
Boat Type: Paceship Westwind 24
Post by MQMurphy »
Neat rig, Rick. Nicely done.
- Mike Murphy
S/V Ikey Boy
1968 Westwind 24
Summersdawn
I think the trickiest part was determing where to mount it, and how long to make the arm. I wanted enough room to be able to use the companionway while the arm was out. Peter, is this for your Vega or San Juan? If it is for your San Juan, I can take some measurements if you would like.
Rick
Summer's Dawn
24 San Juan #380
Peter
Boat Name: Pagan
Post by Peter »
Rick: It's for the Vega. The San Juan has an "in-dash" Norcross digital gauge on the port side.
Peter
Victoria BC Canada
Albin Ballad 30
