Cockpit: Progress?
Posted: Fri Jul 22, 2005 8:38 am
I don't know if I am progressing or moving backwards, but here are a couple of pictures I posted to my web site today that show where I am on the cockpit modifications.
This picture shows the new cockpit sole that has been partially faired with the cockpit drain holes completed. The new hatch hole has had the core removed around it and filled. The old guage holes are also filled.
The gaping hole in the seat structure is for the new top loading access hatch. I guess I am now officially committed to new lockers. Actually, I think that I should be committed! The plan here is to use the skin from the cutout to form the new locker lid. It has a bit of a pain to remove the plywood stringers underneath the seat skin and lid to apply the gutters and lid core, but I have that completed on this side. You can see the underside of the lid skin resting inside the locker cut-out.
This shot shows the cut-out for the new locker. The first step will be to fill the rectangular area of the old seat locker. Next, I'll adheare the U-shaped gutter section to bottom of the cockpit seat. I will then add a molded section to the front of the locker cut-out that will form the "lip" recess. I have the molds for this side nearly completed and hope to have pictures soon.
You can't really tell from the picture, but the top of the rudder tube has been repaired aft (the wooden tube mold is on the lazerette with all the junk).
Here is a picture of the top of the locker lid.
Hopefully this will work out to be something worth the considerable effort.
Joe
Joe
