Hi All,
I thought I would let you all know that I have discovered, the expensive way, that you should never use PB Blaster near ANY engine or transmission seals.
I needed to remove my shaft coupling so I sprayed the bolts with PB Blaster thinking nothing of it. Evidently some of it dripped onto my transmission output seal and when I went to the boat he next day the majority of my transmission fluid was in the pan and not the transmission.
My transmission is a 2003 ZF v-drive and had never ever leaked a drop. After speaking with a few mechanics about this they know it well. PB Blaster can eat engine seals, transmission seals and plastic cups. Keep this stuff far away from any output shafts, engine seals or seals you don't want leaking.
PB Blaster is great stuff but very dangerous to the tune of $800.00 on my transmission. Use it with caution!
Warning about PB Blaster!!
Maine Sail
Shoalcove
I had the exact same thing happen to me although I never knew that the PB Blaster was the problem. Had to replace a damper plate and used copious amounts of PB Blaster to loosen all the bolts and, voila, next day my tranny fluid is in the bilge. A little late for me but maybe someone will be saved the trouble.
BTW I still think PB Blaster is great stuff. I'll just be more cautious if I get another can. It is not available here in the frozen north.
Best regards, David
Best regards, David
