- - Replaced the upper and aft lower chainplates
- Built a new knee and new chainplate for the backstay
- Fabricated and installed reinforcement posts for the main bulkhead
- Dropped the mast, painted it, added compression sleeves, replaced hardware & electrical, and replaced the standing & running rigging
- - Repaint the boom
__________________________________________
Nevermind never had compression posts on the main bulkhead, although every other Triton I've seen has had them. The posts actually seem to be intended to resist buckling of the main bulkhead rather than take compression loads. The factory installations I've seen don't actually reach all the way to the hull. I decided to duplicate this type of arrangement, which eliminates the chance of creating hard spots in the hull around the base of the main bulkhead.
I decided to laminate posts from 1/2" Baltic birch exterior plywood. My design called for 2" width and 1.5" depth, which means I needed three layers in the laminate. I set up a jig to rip 2 1/16" strips from a sheet of birch ply with a circular saw.
A closer look a the jig...it's just a base plate for the saw (a blade-left Porter Cable) along with a rudimentary adjustable "fence". If I had it to do over again I'd use one of the classic "long straightedge" methods to make the rips, because this type of jig pinches the blade too easily (because the "fence" rides on the outside of the piece being ripped).
Twelve cut 60"x2" lengths of ply...
Next step was to laminate the beams. I coated each lamination with unthickened West epoxy, squeegeed off the excess, and then clamped the three layers with light pressure.
After the laminated beams were fully cured, I first "edge jointed" them on the router table using a long straight bit. I had cut the laminations a little wider than the 2" nominal width to allow for this smoothing. Then, I laid out the end cuts and ran a 1/2" roundover bit down the two front edges of each beam.
The completed beams: jointed, rounded over, cut to length, and sanded for varnish. I set up a varnish rig with two sawhorses and small nails in the end of each beam. Over the course of several days I applied 5 coats of gloss and a final coat of satin spar varnish. I'm using McCloskey's Man-o-war.
Next came a test fitting in the boat. Having pre-drilled 5 bolt holes in each beam using a drill press in the shop, I temporarily clamped each beam to the main bulkhead and drilled through the bulkhead with a #7 bit. After drilling I tapped each bore with 1/4-20.
Wrapping up: the final mounting of the finished beams. After the last coat of satin varnish had cured, I took the finished beams down to the boat again and mounted them with 3" 1/4-20 machine screws. There are 5 bolts in each beam - they are spaced every 12" on the long vertical beams (which are about 56" long) and every 10" on the short diagonal beams (about 48").
