Peter,
Since this thread popped up with a new posting, I re-read your description, and something jumped out at me that I hadn't noticed before:
Peter wrote:When the legs are removed a threaded cap plugs the thru hull. These caps are hidden behind the setee locker doors.
When I first got my Alberg, I was looking for a way to cap off some un-used through hulls (I wanted to remove the gate valves and cap the NPS through hulls directly for future use).
I was never able to find any sort of cap to fit on NPS threads (which kind of makes sense, although I did find them in larger diameters - not sure how they actually work though), so I just moved forward, which entailed installing all new seacocks and through hulls in the "keeper" openings, and closing off the others permanently with fiberglass.
However I'm still curious what you used to directly cap off a through-hull, assuming that it's NPS (they all are, right?). I suppose since it's above the waterline, you may have simply pressed an NPT cap onto them (?) From your link:
Oh, and now that I look at the photos again, I have another question: In thinking of boats on stands on the hard, there's always that chain that runs through under the boat, to keep the stands from splaying. What does that with the legs? I see the lines going fore and aft to keep the legs from moving on that plane, but what about if, say, the boat wanted to lean to starboard; what would keep the starboard leg from "kicking out" away from the hull, perpedicularly?
I see that it works great, so I'm not criticizing them; I'm just curious how they work. I even want a set :D Of course it helps to have your tidal range.
