10 days in the yard
Posted: Mon Jul 07, 2008 1:33 pm
by s/v Groovy
It has been a long time since a post, I really need to say Thank You to all for keeping me inspired by all the great work being done out there. There is no way I could have completed this without what I have learned here.
My job keeps me too busy these days and this was all done in the evenings and weekends.
I really needed new bottom paint, but since it's all connected...
With weather cooperating, and after 10 days in the boatyard I...
repainted the decks, removing and rebedding all hardware
new bottom paint
sanded, rubbed, and waxed the topsides
stripped, sanded, and oiled the toerail
removed and revarnished all cockpit wood
replaced the rudder bearings
added the name to her transom...
before,
after,
Posted: Mon Jul 07, 2008 4:29 pm
by Summersdawn
Very nice!
Posted: Mon Jul 07, 2008 7:30 pm
by Triton 185
Well done...you have done a lot of work in a short time. Hope you get some sleep when she is back in the water.
Posted: Mon Jul 07, 2008 10:17 pm
I know! I read that list and was thinking it might easily have taken 10 months, not 10 days.
I love the "font" you used for the name; very groovy. Did you make that yourself?
As an aside, we used to make our own kayaks out of fiberglass in Ye Olde Days, and for a while there was a bit of a craze for using some wild, printed "windbreaker" fabric for the first (outside) layer. That resulted in boats known as "Flower Power," "Stained Glass," etc. :D
Posted: Tue Jul 08, 2008 6:24 am
by Hirilondë
You did have a busy 10 days. Looks great! Your name looks like it was painted on Goldie Hawn in her early TV days. (dating myself as well as the word 'groovy')
Posted: Tue Jul 08, 2008 8:43 am
by MikeD
Interesting way to attach the forward lifelines to the pulpit. I've been mulling how I'm going to lower the forward ends of mine. What sort of hardware did you use to attach the turnbuckle to the leg of your bow pulpit?
Posted: Tue Jul 08, 2008 11:57 am
by s/v Groovy
Yes, very busy, up @ 6 to worked 7-3, boatyard 3:30 - 9:30 or 10 (I got locked in twice) in bed by 11 usually, and long weekend days. I couldn't have done it without my Wife whom held the other end of the hardware while I either removed or reattached it, she also did the toe rail oiling. I wanted to paint the bilge and was going to varnish the toe rail, but I decided to oil any wood I cant remove. The bilge is cleaned but not painted, next time.
I still have to polish the cabin and cockpit gel coat, and gelcoat the void repairs I did along the topside edge, just under the toe rail. Anything I could do while back in the slip I'll do there. I don't think I would have been nearly as motivated without the $25/day boatyard fee. I've seen what can be done with here planning and a worklist.
The deck painting was by far the biggest part of the job, mostly the hardware and prep work. I could have let it cure longer, but after a few touchups it will be fine. A PO painted blue over the original blue nonskid without removing any hardware
The name is a sticker a friend designed based on a font and a piece of retro fabric I found. A sticker shop printed it for $60, like a photo, said it should last 5 years in the sun.
I ran the lifelines to the outside of the pulpit so I could but the 6'7" inflatable up there if I wanted too (just fits). There is an attachment point and then a turnbuckle up there.
I did have the help of my new Fein orbital sander & vacuum and a multimaster (great tools).
Aside from the lack of sleep, scrapes and bruises, my hands and wrists took the brunt of all the work, but after a few days rest are feeling better
I also scraped and polished the prop, lets see if the barnacles can grab onto that, somehow I think they still will get a hold...
Posted: Tue Jul 08, 2008 12:08 pm
by s/v Groovy
Oh, I also need to mention my lucky boatyard hat....
Posted: Tue Jul 08, 2008 6:16 pm
by Summersdawn
It co-ordinates nicely with Britton's socks.
Posted: Wed Jul 09, 2008 10:13 am
by feetup
I read a report a number of years ago by some chemists who were trying to synthesize the glue that barnacles and oysters use. They had encountered endless problems but they had several pages of glowing reports on what a fabulous adhesive it is. Works under salt water, nearly instantly, adheres through slime to almost any surface, rough or smooth....
Tim J
