Since Bolero was basically a clean sheet of paper, I put a lot of time and though into coming up with a great rowing station. I am now on my 4th or 5th iteration, but I think I may have it.
My plan all along was to row standing up with a single deck mounted oarlock.
With that in mind Tim installed and bedded a pair of stout oar sockets adjacent to the toe rails on both sides.
I decided on a Carlisle 2 piece river rafting oar for ease of storage. Each piece stores nicely under the cockpit side decks ready at a long moments notice.
After a number of iterations that seemed to work but wouldn't fit in the storage under deck or would rub the coaming, I ended up with this.
I really like how well the oar stores on deck when not in use. This was one of the reasons that I decided on cabintop winches instead of the traditional side deck mount.
The oar lock is a hybrid combining the upper part of a clamp on oar lock with the base of a 5/8 inch custom turned (to match the 1/2 inch socket) bronze bottom. I found this stand off idea from some photos of old rowing boats and I needed the elevation to miss hitting the top of the coaming.
Even though the oar lock standoff allows me to clear the coaming pretty well, I still leathered the oar to protect the varnish on the top of the coaming.
I still have the oar mounted to far outboard. I think I will move it in 12 to 18 inches. This will allow me to row two handed and the oar will be better balanced.
I had meant to row around the bay today to perform a final checkout but of course the stormy wind wasn't cooperative. Even though I don't quite have the mounting quite right, rowing at the mooring felt easy. My thought is that in wind to light for Bolero to sail, I should be able to row at about 1 to 1 1/2 kt easily. And for a short time at 2 kts. I will update when I get a chance.
Cheers, Bill
