I bought a Whale Titan pump to use as my emergency pump. Not wanting to blast a hole in the cockpit somwhere to place their new bulkhead plate with their free advertising, I looked into reusing the old location. First, I cut the flange off the old bilge pump(it was pretty well shot inside) and mounted the Titan to a backer board and started noodling.
After some trial and error, I got a good location and fit below. Then it was a matter of gluing some scrap together and cutting a doughnut that would supply a stop for the bronze plate as well as a recess in the wood at the base to encapsulate the rubber gaiter. Best of all, you can easily seat and comfortably pump while holding the helm. It's easy to reach from the companionway as well.
28gpm is not alot but in conjunction with the Rule 2000 pump, it could be enough to clear the bilge long enough to find a leak.
