Alberg 30 refit
Cruiser2B
- Boat Name: Salacia
- Boat Type: Alberg 30
Alberg 30 refit
I am finally making some progress but also opening a can of worms. My hull is full of blisters.....
Here is what I uncovered:
http://svsalacia.blogspot.com/2015/06/a ... moval.html
www.svsalacia.blogspot.com
Preparing to get underway!!
TampaBay
- Boat Type: Coronado 15
Re: Alberg 30 refit
I took a look at the blisters. I think you are on the right path. That West System guide sets the standard.
Cruiser2B
Re: Alberg 30 refit
Tampa,
Thank you. I printed off the west system blister guide. Gonna study up on it while is gather supplies. Boat has been on the hard for about 9 months. Hull should be quite dry but going to let it sit without paint and covered for another month before beginning repairs. In the meantime there are about 100 other things that need attention.
Cruiser2B
Re: Alberg 30 refit
http://svsalacia.blogspot.com/2015/06/a ... 2.html?m=0
making progress and I met a young couple cruising from CA to MA
Cruiser2B
Re: Alberg 30 refit
Happy 4th of July everyone
Small update, scraping and sanding the paint off is just about done!
http://svsalacia.blogspot.com/2015/07/a ... -2015.html
Cruiser2B
Re: Alberg 30 refit
small update
Looks like the bottom paint had trapped a bit of moisture in gelcoat, a few picture have been been added to my blog
http://svsalacia.blogspot.com/2015/07/a ... -hull.html
Cruiser2B
Re: Alberg 30 refit
Cruiser2B
Re: Alberg 30 refit
http://svsalacia.blogspot.com/2015/08/a ... joint.html
found more issues with our ole Alberg 30 as I continue to dismantle her...but nothing that cannot be fixed....
- Boat Name: Ella Marie
- Boat Type: Bristol 27
Re: Alberg 30 refit
I hated the taking apart process. It seemed to never end.
Cruiser2B
Re: Alberg 30 refit
http://svsalacia.blogspot.com/2015/08/a ... nt_19.html
A few more photos of hull to deck joint that failed on my Alberg 30. Working on a plan to repair
David VanDenburgh
- Boat Name: Ariel
- Boat Type: Cape Dory 36
Re: Alberg 30 refit
I've discovered that I'm an expert at ripping things apart. It's the putting them back together part that I do a bit more slowly. Ha! Best of luck!Lloyd wrote:I hated the taking apart process. It seemed to never end.
Cruiser2B
Re: Alberg 30 refit
http://svsalacia.blogspot.com/2015/08/a ... n-and.html?
Started to formulate a plan of attack and been spending money!
Re: Alberg 30 refit
Let the fun begin, or I should say let the fun continue. Getting all the hardware off can be a real pain. Looks like you have a good supply of epoxy to get the recore started. Will be following along.
TampaBay
Re: Alberg 30 refit
Wow! The deck will be awesome when you're done.
Cruiser2B
Re: Alberg 30 refit
thank you, it will take lots of work and even more sandpaper and epoxy but should worth it at the end of the dayTampaBay wrote:Wow! The deck will be awesome when you're done.
Cruiser2B
Re: Alberg 30 refit
http://svsalacia.blogspot.com/2015/09/a ... otten.html
cut into the core today...WTF did i get myself into.......
Cruiser2B
Re: Alberg 30 refit
Got the lazarette balsa core all cut and in place, and a few storm photos in link below
http://svsalacia.blogspot.com/2015/10/a ... oring.html
Cruiser2B
Re: Alberg 30 refit
Progress is slow but for good reasons this month
http://www.svsalacia.blogspot.com/2015/ ... -deck.html
Cruiser2B
Re: Alberg 30 refit
A bit more progress to report
http://www.svsalacia.blogspot.com/2015/ ... -cont.html
Happy Thanksgiving!!
Cruiser2B
Re: Alberg 30 refit
Moved onto recoring the port side deck. The weather has been great..not sure how much longer it will hold out for outdoor boat work
http://svsalacia.blogspot.com/2015/12/a ... re-on.html
Modify message
Modify message
Cruiser2B
Re: Alberg 30 refit
More progress re-coring A30 side decks, warm weather is helping
http://svsalacia.blogspot.com/2015/12/a ... -side.html
Cruiser2B
Re: Alberg 30 refit
Work continued over Christmas holiday as warm temperatures are still making outside boat epoxy work possible
- Wood Whisperer
Re: Alberg 30 refit
Wow- first new post since Dec 29 when I made mine. This place really has died. Sad thing too
Cruiser2B
Re: Alberg 30 refit
In spite of bad weather I've managed to make a bit of progress on the Alberg
http://www.svsalacia.blogspot.com/2016/ ... epair.html
Cruiser2B
Re: Alberg 30 refit
Cruiser2B
Re: Alberg 30 refit
Re: Alberg 30 refit
Really great job on the mast beam rework. Looks like that will hold the stick up with no sagging, no problem. Please continue to post updates. I need the encouragement of watching others work on their projects. I've been sidelined dealing with an aging Dad (94) with his hospital and rehab stays seems like for the past year. Great work!
