De-Waxing solvent
- preserved_killick
- Boat Name: Seagrass
- Boat Type: Alberg 30
De-Waxing solvent
What do you all use for a de-waxing solvent? Are the marine specific dewaxers really any better than just toluene? Any other readily (hardware store) solvents recommended??
-Jeff
-Jeff
I just learned xylene is just a 'better' version of tolulene. Something about an extra 'ester bond' (or something like that - my eyes were glazing over at that point) in the chemical composition.
I remember reading something on one of the Awl-grip solvent products about xylene being the main (and possibly only) ingredient. On the other hand, compared to how much you really need the brand name doesn't cost all that much more in the big scheme of things? e.g. when you are applying a thousand dollars of primer and topcoat is a $5 savings worth thinking about?
just my 2c
just my 2c
I've used Interlux Solvent Wash 202 with good results. I don't have experience with any others though.
Very important is to have a huge supply of clean rags/towels, and to use a fresh surface constantly. At yards they use a sort of "wiping towel" in a box (can't think of the name right now - Handi-something). It's paper of some sort, I'm pretty sure. (Will check and update.)
- hebert01
- Boat Name: Allegra
- Boat Type: Pearson Ensign
It'd hardly say that! Maybe Ensigns were fast in 1962, but not so much today. Doesn't mean I can't pamper her, though... ;-)
Actually, I had stripped all the old bottom paint this year with all kinds of different strippers and stuff. So I wanted to clean the bottom thoroughly to insure a good clean substrate for painting.
Truth be told, though,...I just washed it pretty good with mineral spirits this afternoon, threw the first coat of bottom paint on, and called it a day.
Oh, and for anyone keeping score of paint stripper effectiveness...I'd declare good old PeelAway 1 the unanimous winner over both Soy-Strip and Aquastrip. Note that this was NOT PeelAway Marine...just the inexpensive homeowner stuff from HomeDepot. This goes against the results observed in the Practical Sailor evaluation.
It wasn't even a contest, really. In 50-60° weather, PeelAway worked pretty well (90+ percent removal), Aqua-Strip was so-so (50-75%), and Soy-Strip was bottom of the pack (<50%, and the messiest to work with).
Evidently all of these chemicals are less effective in cool weather. In the northeast, we can't be waiting around for 70° weather to do all our grunt work. That's when we *sail* our boats! The companies should consider that when formulating the product. A 40-70° optimized formulation would make good sense.
All required subsequent sanding and scraping, however, so there's no miracle product out there. I really did not enjoy this job at all.
Ed Hebert
ALLEGRA - Ensign #998
- hebert01
Rachel - Exactly. That's why I was asking. My old bottom paint was patchy, with pieces randomly chunking off. There was also probably 40+ years on there, so I can't entirely blame it on a waxy bottom. Nevertheless, now that I'm starting from a wonderful new baseline again, I wanted to follow best practices.
Ed Hebert
- preserved_killick
To answer my own question, a week later..
I ended up using a product called Prepsol made by DuPont. It is specifically made to remove waxes & other containments before painting. This option appealed to me because 1. It gets very good reviews and is widely known in the auto painting world. 2. Availability, I bought a gallon for $24 at a local auto parts store.
I actually did two wipe downs. First with the Prepsol, then another with denatured alcohol. I was using the new Yacht Primer from System Three and wanted to be sure the prepsol didn't leave any residual oils that weren't compatible with my water based primer.
It seemed to work fine, and didn't smell too bad. I'll report back if all my new paint falls off.
feetup
While not an answer to the OP I thought this might be of interest.
Of almost all common solvents out there, only acetone and alcohol do not contain some benzine. Lacquer thinners, toluene, xylene, mineral spirits, and good old paint thinner all contain at least a modicum of benzine.
Benzine is proven to be carcinogenic, through contact with skin. Then there is MEK, but that is another story
I lost a much loved relative to cancer directly caused by skin contact with solvents.
The moral;
It doesn't matter what solvents you use, wear nitrile gloves, and avoid breathing the vapours. We restore these old boats to breath the air we sail through, not to pass them on to someone else in the estate sale.
Tim J
The moral;
Tim J
MikeD
- Boat Name: Totoro
Better yet, "report back" with pictures of your paint job!preserved_killick wrote:I'll report back if all my new paint falls off.
Mike
Totoro (SS23 #626)
Totoro (SS23 #626)
Summersdawn
Virtually all paint strippers contain wax to slow the evaporation of the solvents used to break down the bonds in the paint you are removing, so anytime you use stripper, it should be wiped with a solvent. The instructions usually call for a wipe with mineral spirits or something similar, so I'm you'll be fine.
Rick
Summer's Dawn
24 San Juan #380
Summer's Dawn
24 San Juan #380
