Note: fairlead has been removed. It's hard to see, but the end of the toerail was slightly lifted and split.
It's now been repaired, and finished, but I need to do something about a fairlead.
I question the strength of the toe-rail itself. It's through bolted, and I'm able to get to the nuts underneath, but the rail is so tall and thin, I was originally thinking that I needed to do something different as this boat will sit on a mooring, and will likely see some weather.
I found this image of an Alberg with the same toe rails and they built a little block that sits just inside the rail, that the fairlead is mounted to. I'm sure it is through bolted and backed up:
Now, I'm second guessing myself. Are the toerails plenty strong enough?? I mean, the pull should be mostly down. Right? I looked at Tim's Glassando images here:
http://www.triton381.com/projects/resto ... rdware.htm
His Skene chocks are held on by what looks like smallish screws. Surely if the hardware say some upward or outward forces the fairlead would tear out?
I should also admit that I've never owned a boat that sat on an ocean mooring before, and would prefer to overkill the setup for peace of mind, but then I don't wish to start adding stuff, drilling holes willy-nilly. Nor do I want to repair and serious damage to the toerail. I imaging replacing a section of this would not be fun.
I'm interested in other's opinions in the matter. Whos's got a boat on a mooring with exposure?
Do I add the blocks to support the rail and fairlead? Should I just stick the fairlead right on the rail and watch it?
http://picasaweb.google.com/fongemie
-jeff
