Stripping/repainting engine
Wondering what's the best way to go - paint remover/sand/soda blaster?
"All men die, but very few men ever really live!
Have a great day!
Joe
Have a great day!
Joe
engine
It's in the boat right now, but I'm plannig on pulling it and putting it on a stand. Not planning on dissasembling. I'm thinking about converting the aft portion of my bilge into diesel tank and figure if I do I might as well clean the engine up and get some better protection (paint) on it.
Have a great day!
Joe
Have a great day!
Joe
- Peter
- Boat Name: Pagan
- Boat Type: Albin Ballad 30
In my experience, if the engine is not being torn down and boiled out:
-Plug all orfices
-Remove belts
-De-grease with a spray-on engine cleaner, then wash with hot soapy water, and rinse well.
-Use a rust remover to clean off any rust
-Wire brush off any loose or flaking paint
-Blow engine dry with compressed air.
-Mask all hoses, fuel and water (if you leave them on) and factory labels.
-Spray engine with desired color engine paint (my preference is the original factory color.)
Unless the old paint is a complete diaster there's no need to remove it all.
I avoid pressure washing because 1: I don't have one, and 2: it tends to drive dirt and grease where it doesn't belong.
Hope this helps!
My 26 year old 2GMF:
-Plug all orfices
-Remove belts
Hope this helps!
What do you do if one is rebuilding the engine, including hot tanking the block, manifold, head, and oil pan? I was told that the machine shop will usually prime the casting for you. What type/brand paint will you recommend?
Peter, your Yanmar looks clean enough to eat off of.
Ray D. Chang
Triton 106 in Berkeley, CA
- Peter
- Boat Name: Pagan
Thanks, Ray. I like to keep it smelling sweet :-)Ray wrote:Peter, your Yanmar looks clean enough to eat off of.
I used a can of Yanmar's engine enamel in a spray-can. I'm not a great fan of spray-can paint jobs, but this one is holding up very well.
A quick Google turns up a lot of spray-can options, but if I were going from scratch on a complete rebuild I'd probably go thePORroute. I used that stuff on the inside of my boat trailer brake drums and it prevented rust, despite frequent salt water submersion.
A well painted engine is easy to keep clean.
<<Try Googling molasses rust for some verry interesting info. Seems to be big in Australia.>>
I have read of people using Coke to remove rust as well. I came across this yesterday..a water based rust remover:
http://www.theruststore.com/Evapo-Rust-Gallon-P1C1.aspx
Supposedly it is meant to be used by soaking the rusted part in the solution, but I think it could be bushed on or sprayed on successfully also. I've ordered a gallon so we will see.
- Boat Name: IRIS
- Boat Type: Dickerson 36 Ketch
stripping/repainting engine
Hi Joe,
I'd suggest that if you have the availability of someone who can walnut shell, or "carefully" media blast the engine I'd follow that route. In the yard where I've kept my boat they have access to a "traveling" media blaster who will swing by the yard and blast engines, trannys and or anything else they require. They charged (last summer) $100 and its amazing to see...Tape off the engine "delicates" with heavy zip lok plastic bags & duct tape & in 20 minutes -done!! Blow everything off with air and good to go.
Prime with epoxy paint or a good quality etching (the green stuff) primer & paint. Me, I'd spend the few dollars for a quart of Imron Industrial paint at the local automotive store -all of $55 & well worth it.
Me, on the other hand, spent a winter 3 years ago rebuilding my Westerbeke 4-107. The "blaster" was un-available the week I removed my engine & I just "had" to move it north to New Hampshire to the garage. Stupid me! The engine had sat in the bilge for 35 years & looked it. So, as I took the thing apart (total re-build & new injection pump) I found ways to remove rust - none of them fun. Wire wheels on drills, scrapers and scrapers. did I mention degreasing??? fun.
I eventually settled on an electrolosis bath for non critical (like engine block & head) that worked wonderfully - hook up to the battery charger, drop in the liquid - next day - no rust. Saved tons of time, but still a PITA. Ospho works well on rust, as does phosphoric acid as a post/pre treatment prior to paint. (that's what's going on when folks use coke - phosphoric acid). My basement work shop was cool all winter ( 45 degrees) so I used a moisture cure urethane aluminum filled paint 'cause it cures in cold weather. Worked O.K., but I'd use a 2 part urethane or high quality enamel next time - A shiny finish that sheds dirt/water/gump better. I know folks have good luck with POR 15 on engines -It's tough stuff & nice colors.
After all this was done, a buddy of mine trailered a large snow blower (This is New Hampshire...) to a local "sandblaster". The whole thing was blasted & painted with etching primer for $75 - what's not to like?
Mike
Mike
Just reporting on the Evapo-Rust: I have derusted every old tool in my shop. The stuff really works--the longer you leave the rusted part in a bath of the solution the cleaner it gets. If you take it out of the bath and let it air dry it turns the part sort of gun-metal dark gray but the company claims it will not rust again.
It's permanent; doesn't rub off. I put a 50 year old pipe wrench that had been rusted since it was new...I left it in for two days..it looks brand new now. Really amazing. It is also not caustic. I picked the tools out of the bath with bare fingers, no burning, no particular odor; it seems very benign.
