Hi guys, I'm looking over my mast today...
Wondering if there are any cool chemicals that knock back the corrosion on aluminum. My mast step and mast have become one piece, I want to get the step off so I can bolt it to the deck.
Spray on corrosion removers?
Mario G
- Boat Name: Don't Wake Me / Shaken Knot St
- Boat Type: Chrysler C-22 &C-26
Re: Spray on corrosion removers?
CLR found in most stores should work , Have you tried a steel brush? either I'm going to have my boom powder coated or clear coat it.
A good automotive wax applied aften???
LazyGuy
- Boat Name: Paper Moon
Zach,
I found that PB Blaster works great for separating aluminum and stainless so it should work with cast and extruded aluminum. Be careful, it eats rubber and many non-metal compounds so be careful where you spray. Give it a healthy does, give the step a few wacks with a hammer and return tomorrow to repeat.
Good Luck
Good Luck
Dennis
Dennis
