Outdrive grease points
alorio1
Post by alorio1 »
I have a 4,1 Alpha outdrive unit that seems a little noisy when turning....sounds fine while going straight. I am told that there are u-joints on this unit which require greasing (u-joints). Problem is.......I can't seem to locate the spot where grease is injected into the joint....really I haven't found the joint yet......can someone enlighten me as what has to be removed so I can service these u-joints.
Thanks in advance for any comments/info.........Joe
