Plumbing question
- Canuck
Plumbing question
I plan to tee my head and galley sinks and possibly a shower sump pump into 1 common drain going to a 1" bronze seacock. My question : could I also draw water for my Lavac head intake from this same seacock if I put a tee close to the seacock ? Would the sink drains have to be plugged tight for it to work ? I will have a shut-off on the shower drain as it will be rarely used.
I don't see any reason why it shouldn't work, so long as the tee is below the waterline. The (assumed) extra hose run length might mean you need a few extra pumps to get a full flush, but that's no tragedy.
I suppose there is some element of risk in having an additional connection (which could someday fail and sink the boat) below the waterline, but I don't suppose that the risk is any greater than if the head had its own dedicated intake. The argument could be made either way.
Summersdawn
I don't think this will work. You can't draw water from the same opening as you discharge. What would happen is your discharge would just get recirculated.could I also draw water for my Lavac head intake from this same seacock if I put a tee close to the seacock ?
Rick
Summer's Dawn
24 San Juan #380
Summer's Dawn
24 San Juan #380
I'm all for minimizing the number of openings in the hull, but to me it never seems like good practice to use a discharge also as an intake. I'd rather see intakes combined into a single larger fitting, or discharges combined, but ne'er the two shall meet, in my opinion.
A30_John
Canuck, I would be extremely cautious about doing this. First, I don't see how it could work without recirculating waste through the head. That should be avoided. (Imagine hanging over the bowl when you're seasick-a clean bowl would be more inviting. You get sick. Thinking it's all over, you flush. And, then, feeling sick again, you open the lid to continue and what are you faced with...) Second, I personally would not want the head waste anywhere near my galley sink. If you use the head when you're at sea, the seacock is open, and everything is gurgling and burbling away down there, there could be a little back siphoning into your galley sink, yuk, this is where dishes are washed, teeth brushed etc. then possible splashing on your food preparation areas. Perhaps I'm overly cautious here, but a few germs can unsuspectingly turn into a serious safety issue.I plan to tee my head and galley sinks and possibly a shower sump pump into 1 common drain going to a 1" bronze seacock. My question : could I also draw water for my Lavac head intake from this same seacock if I put a tee close to the seacock ?
Also check the size of the seacock for your head outlet. I think the Lavac specifies 1.5".
BTW, if you're looking for further information on the recommended installation for the Lavac head, the user manual can be downloaded online here:
http://www.blakes-lavac-taylors.co.uk/prod03.htm
You've done a wonderful job on your hull. I'm looking forward to seeing more pictures!
John
Ric in Richmond
- Boat Name: Andiamo
- Boat Type: Alberg 35
"I am going to plumb my head intake and head drain and sink drain all onto the same thru hull"
Did I read that right?
That has to be a recipe for disaster.
Scenario 1-
Lets say a critter takes up residence in the thru hull. Then you go to "dump" over board and it is blocked. Where does the water go? Up into the sink...the same sink you wash dishes in.
Scenario 2-
You recirculate a bunch of the "old" water into the "new" intake water (which doesn't get flushed all the way thru the line) and the "new" water sits in the intake line...for a week or three while you aren't using the boat. That ferments into a primordial oozes that permeates any line you could possibly devise leaving a smell that will wake the dead.
Scenario 3-
You sink is slightly off the center line and back fills when you heel on one tack. Some of the things you have pumped into your drain line drain line "float" and they "float" to the top of the water column and into your sink.
I am all for minimizing thru hulls, but read that again and tell me you think that is a good idea.
I'd say there will be vomiting on board and it won't be from motion sickness....
Scenario 1-
Scenario 2-
Scenario 3-
A30_John
That sounds like a more palatable alternative. I guess it's all in the interpretation..I had interpreted the first post to mean that the discharge for the head's SINK, the galley sink, and shower sump were being ganged, and that the head TOILET would draw (potentially) "grey water" from this line for flushing.
John
- Canuck
Thanks everyone for your input. To clarify: I am only talking about the 3/4" intake to the head. I will certainly not have the head outlet near any other through hulls. As far as some soapy grey water being drawn into the head inlet, I don't see how that could be a problem. Also, it would be very unlikely that someone would be draining a sink at the same time that someone else is flushing the toilet. With everthing static there should only be clean seawater sitting in that line when water is being drawn into the head.
I read somewhere that some production boat builders do this, which is where I got the idea.
Thanks again.
Ernie
Thanks again.
Ernie
Well, production boatbuilders do a lot of things in the interest of saving time and money--it doesn't mean it's the "best" way. One of the beauties of building a custom or semi-custon boat (or rebuilding an old boat) is the opportunity to do better than production boatbuilders.Canuck wrote:I read somewhere that some production boat builders do this, which is where I got the idea.
While I still prefer keeping intakes as intakes and discharges as discharges, you can certainly tee your head intake into the drains for sinks if this makes sense in your situation.
- catamount
- Boat Name: GREYHAWK
- Boat Type: Peterson 34
I have heard of this idea before somewhere else (think...was this in the Head Mistress's book about eliminating boat odors?).
I don't really see anything wrong with recycling the greywater from your sink and shower drains through your head. Some have argued that there is in fact a benefit, as presumably you would be periodically flushing fresh water through the head plumbing.
Regards,
Regards,
Ric in Richmond
My bad....I read "plumb head and galley sinks" instead of "head (sink) and galley sink".
I thought you had lost it! And here it was my reading it all wrong!!.
I agree now.
SINK discharges and toilet intake are probably fine.
I agree now.
Summersdawn
